The serial device must support Modbus/RTU or Allen-Bradley DF1.
Here is how to communicate with the RMC150E (or RMC75E) via serial communications:
- Choose your protocol, either Modbus/RTU or DF1. These are the only ones supported at this time.
- Purchase a converter for your protocol:
- For DF1 (RS-232 Only):
Buy the Allen-Bradley 1761-NET-ENI serial-to-Ethernet converter (http://literature.rockwellautomation.com/idc/groups/literature/documents/pp/1761-pp003_-en-e.pdf) for roughly $550. You will probably also need a null-modem cable and a couple gender changers. Read the attached document "Using the 1761-NET-ENI.pdf"for info on how to set it up for use with the RMC150E. - For Modbus/RTU (RS-232 or RS-485):
Buy the Lantronix UDS1100-IAP serial-to-Ethernet converter for roughly $153. You will probably also need a null-modem cable and a couple gender changers. Read the following document for info on how to set it up for use with the RMC150E "Using the Lantronix UDS1100.pdf"
