Again, I have been handed a system with not enough flow. Years past I would have never known. What are my options?
Take a deep breath and relax. Then get your pointer finger out and point at the hydraulic designers because they screwed up. There is nothing you can do until the design is fixed. It isn't like you can fix this in software or with a controller. If the controller outputs 10 volts and the system isn't going fast enough then it is time to take a break, drink coffee, play from Freecell and let the hydraulic people spend their time figuring out where they went wrong.
The hydraulic designers should know about these equations below. If they don't then they really shouldn't be designing hydraulic servo systems.
There is an equations called the Valve Control of Cylinder Motion that estimates the maximum speed of a hydraulic system. Books by Jack Johnson explain this formula and go through the derivation. Better yet a very old book by George Keller that not only provides the formula for the maxim speed but also how long it takes to reach the maximum speed. This may be critical on short point to point moves. Hydraulic Systems Analysis is also cheaper but I see the price went up from $35 to $50.
See
http://www.hydraulicspneumatics.com/Bookstore/Personally, I prefer hydraulic simulations but for some reason no one seems to be willing to buy a good simulator but they are willing to waste your time trying to control the uncontrollable or defy the laws of physics.
Stuart, you are not alone. This happens all the time.
Sorry to post again so fast.. At home wound up. Don't know what to do. Struggle with dead-band,
You shouldn't need to use the dead band eliminator unless there is a dead band in the valve. Servo quality valves don't have a dead band.
The hydraulic designers can save a little by buying cheap valves with dead band and not realize you will waste much more money in yours and others peoples time getting the cheap valve to work adequately.
Do you and the hydraulic designers work for the same company? Usually when the control and hydraulic guys work for the same company it is easy to convince a manager to spend a little more on a good valve and make up the difference in cost with save time. If the hydraulic guys work for a different company then this is almost impossible. They will sell cheap and don't care about how of if the system will ever be controlled.
feed forward, anything outside of wizard set-up. What is a little, what is a lot? It kills me that I can not master this. They want it up so fast that I can't play to learn.
That is a problem. It doesn't sound like the hydraulic designers are making it easy for you. Feed forwards assume the system is roughly linear. It sounds like your system isn't linear at all. A linear system is easy to tune.
The auto tuning should work but it won't for systems that have over lapped spools and require a dead band eliminator.
Do you have any plots that show what you are complaining about?
