I used cubic interpolation methods but Actual postion didn’t follow correct curve profile… I used all curve interpolation method . Auto constant vlocity mode also happen overshoot…
I know it is diffilcult for following correct curve profile… but for Minimum Error we want to follow desired curve data for smoothy linear curve…
Could you give me any help??? Do I need programming work for minimum spline curve between point and point exept linear segment curves ??
Please Let me know how to use program with smoothy linear curve and minimum spline data in RMCTool software…
I think the problem is that the axis is not tuned correctly. I assume the axis does not properly follow other motion profiles either, such as a Move Absolute command.
If you post some .rmcplots files, we can give some tips on how to improve the tuning.
