# QUAD Module Space Requirements
**URL:** <https://forum.deltamotion.com/t/quad-module-space-requirements/399>\
**Category:** Motion System Design\
**Created:** [May 16, 2016, 7:34pm UTC](https://forum.deltamotion.com/t/quad-module-space-requirements/399 "2016-05-16T19:34:29Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![ChadBush\_EE](https://forum.deltamotion.com/letter_avatar_proxy/v4/letter/c/8dc957/32.png) [@ChadBush\_EE](https://forum.deltamotion.com/u/ChadBush_EE)\
**Post date:** [May 16, 2016, 7:34pm UTC](https://forum.deltamotion.com/t/quad-module-space-requirements/399/1 "2016-05-16T19:34:29Z")
</div>
All,
If anyone can give me an idea of the depth required by the Quadrature module and cabling attached to the front end, that would be great. I have the depth dimension for the actual module and know it’s about a 2" backshell on the cabling, but my current enclosure is only about 7" deep to the mounting plate. My configuration of the RMC150E requires 2 of the Quad modules, so four 25-pin cables total trying to route up or down.
Chad
**Post date:** [May 16, 2016, 7:38pm UTC](https://forum.deltamotion.com/t/quad-module-space-requirements/399/2 "2016-05-16T19:38:56Z")
</div>
If you get a 90 degree backshell, it should fit just fine.
Try 981-25RCE-ND at Digikey: [http://www.digikey.com/product-detail/en/norcomp-inc/981-025-130R121/981-25RCE-ND/1632180](http://www.digikey.com/product-detail/en/norcomp-inc/981-025-130R121/981-25RCE-ND/1632180)
**Post date:** [May 17, 2016, 1:04pm UTC](https://forum.deltamotion.com/t/quad-module-space-requirements/399/3 "2016-05-17T13:04:08Z")
</div>
Thanks Jacob.
That was my first instinct, but not having the cables and controller on hand yet didn’t give me a definite answer that just 90 degree back shells would fit well on those cables and solve the problem. I debated whether to buy the cables from Delta and change back shells, or just make our own.
