In the rmctools manual, it refers that “Tip: For a typical hydraulic cylinder, the Accel and Decel parameters of the Move absolute command should be on the order of 20 -100. The speed is typically between 1 and 30.”
what’s the units of red part?
The units are inches and inches per second. I will update the manual so that it includes the inches.
At the bottom of each help topic, there is a link that says “Send comments on this topic.” If you use the link, then you can email a comment to us and we will also know which topic it is.
