I’d like to make the sine,triangle,square wave signal with Control output.
The Control output regisiter is Read Only memory.
So, I can not write the new value to the Control output register.
How can I make the sine, triangle, square wave with Control output ?
[color=red]Misleading Info here - read on for a better answer
Control loop with P gain of 1.
Sine command for sine output
Open Loop Rate for triangle
Open loop rate with huge ramp rate for square wave
Make haults related to feedback status only.
Okay, I know the method made trignale,square wave by openloop rate commnand.
Could you show me the exam program for sine wave signal output ?
I don’t know how to make the sine wave about Control output.
How to change the Amplitude, frequency ?
The Amplitude of this sine wave is Control output. that is Voltage output.
