QUAD Module Space Requirements
All,
If anyone can give me an idea of the depth required by the Quadrature module and cabling attached to the front end, that would be great. I have the depth dimension for the actual module and know it’s about a 2" backshell on the cabling, but my current enclosure is only about 7" deep to the mounting plate. My configuration of the RMC150E requires 2 of the Quad modules, so four 25-pin cables total trying to route up or down.
Chad
If you get a 90 degree backshell, it should fit just fine.
Try 981-25RCE-ND at Digikey: http://www.digikey.com/product-detail/en/norcomp-inc/981-025-130R121/981-25RCE-ND/1632180
Thanks Jacob.
That was my first instinct, but not having the cables and controller on hand yet didn’t give me a definite answer that just 90 degree back shells would fit well on those cables and solve the problem. I debated whether to buy the cables from Delta and change back shells, or just make our own.
