Ports to open for RMCTools Connection Path?
I’m able to connect to an existing RMC150 unit with an already configured IP address, but I am unable to open the Controller->Connection Path and then Browse for an Ethernet connection on an unconfigured unity, it just times out. I’m assuming this is a firewall issue as the Windows 7 system I have with the firewall turned off finds a new unconfigured RMC just fine. Does anyone know what ports to open for the connection path to work on a Windows 10 setup? Thanks!
The RMC series uses port 1324 for browsing. If this is very old firmware you might need port 50000 opened. I would start with opening port 1324 however and give that a try.
Awesome, thanks!
