Differential Force Scale and Offset for Multiple Cylinders
For systems where one pressure sensor is measuring the cap end pressure of multiple cylinders and another is measuring the rod end, the attached Excel spreadsheet has calculations for determining the Channel A and Channel B scale and offset values. The spread sheet also supports double-ended rod cylinders.
This applies only to the RMC75 and RMC150. The RMC200 differential force is done differently, and is in general easier to use and more flexible.
DiffForceScaleMultipleCylinders.xlsx (13.8 KB)
