stepped electric input signals
Designing a motion system and want some tips? Run into a problem? Talk about it here!
Postby mars_bruce_lee » Sun Apr 10, 2016 10:59 pm
How to use transition function with stepped electric input signals?
What's the relationship between stepped electric input signals and bode plots
mars_bruce_lee
Re: stepped electric input signals
Postby Peter Nachtwey » Tue Apr 12, 2016 1:52 pm
mars_bruce_lee wrote:How to use transition function with stepped electric input signals?
I am assuming the stepped electric input signals are from a PLC and are proportional to the the position.
I would not use the transition command to go to command positions from a PLC analog signal.
I would use the track position (I-PD) command 58. The analog input must be scaled to convert voltage to millimeters.
The master register of the track position (i-PD) command should be set to the scaled position in millimeters.
The track position (I-PD) command only needs to be issued once. After that the axis will always move to the
position pointed to by the master register. This is very easy. Now the PLC can change the electrical signal
anytime and the RMC will move to the position indicated by the analog input.
Stepped inputs signals are inputs. The Bode plot indicates how the system will respond to the inputs.
Peter Nachtwey
Return to Motion System Design
Who is online
cron
