4-20 mA with VC2124
Is it possible to configure an RMC150 with a VC2124 to get 4-20 mA output? I have a valve that requires current input and I would like to use it on my next application.
Thank you,
Leland
Yes it is!
In the RMCTools help, on the Index tab, type “VC2124” and choose VC2124/VC2100. That topic describes how to set it up.
For future applciations, if you order new valves for use with RMCs, make sure to get valves that require a +/-10V command signal. It is easier and cheaper.
-Jacob Paso
