RMC 200. In user program 1 on task 1, I am using Curve Start (86) to run a curve. And master Reg is an encoder target position (which tells log length) and y axis are infeed module position for curve sawing.
And when that first curve is in execution, in user program 2 on task 2, if i do “Set Actual position (49)” to that same encoder axis and set it to position 0 to start another curve.
Will that affect the first curve, since the master register value changes ? Or once you start the curve using command 86, the Master register value (Encoder target position) will be recorded on a separate register, and so when you change the master register value elsewhere, it will not affect the already started curve execution ?
