RMC motion controllers don’t support ControlNet. An EL6652 will work for communication from an RMC to a Beckhoff PLC. We have a forum topic on this, see below link.
A Beckhoff TwinCat device can communicate with an RMC motion controller via EtherNet/IP.
Beckhoff currently has two listed EtherNet/IP scanner options:
• TwinCat driver for using one of the PC’s existing Ethernet ports as an EtherNet/IP master:
• Dedicated EtherNet/IP master device (plug into rack) (includes its own Ethernet ports):
Setting up the communications is similar to adding any IO Device in TwinCAT, simply follow the steps provided below.
In the I/O tree under Devices add a new i…
