I have been tasked with writing a Windows front end that enables you to modify parameters and plot a graph of the servo valves performance.
I have worked out how to communicate with the controlled, read and write values, but when I read back the ‘Control Output’, I am not getting the same results as the ‘RMC Tools’ graph.
I am writing the code in C# and have am using a thread timer to read the value.
Static_Delta_Data.rmc.ReadFFile((int)FileNumber70.fn70StatusAxis0 + axis, Control_Output, RMC_Floats, 0, 1);
I have performed some test and it looks like I am reading values every 3mS, which I know isn’t fast enough.
I just wondered if anyone else has had the same problem and what they did about it.
