Dithering a servovalve
Outdated topic. See Dithering Valves
Some valves require dithering to prevent stiction. At this time, the RMC75 and RMC150 do not have a built-in dithering feature, but dithering can be done with a user program.
The attached project has two different programs that implement dither by continuously changing the Output Bias. One program only applies dither when the axis is stopped (in position control), and the other applies dither continuously.
A dither user program should always run. You can create a “_FirstScan” condition in the Program Triggers to start this user program when the RMC eneters Run mode.
Dither.rmcproj (28.0 KB)
What’s “dithering?” What’s “stiction?” I’m new to both of those terms, but I love the RMC controllers!
the link for the download does not work anymore, is there someone who can make it work or deliver the file to the forum
The file link should work now. Thanks for pointing that out!
