I need a CAN to EtherCAT gateway for RMC200 to communicate with other devices. Can this product communicate with the ECAT module of RMC200? It is an Anybus Communicator-CAN to EtherCAT, Item number AB7311-B。 The picture is an explanation of its EtherCAT, and a separate manual is attached.Or there may be other available product recommendations
Simon,
Yes, that device can communicate with the RMC200 ECAT module. Whether it will work for your specific application depends on the situation. Could you describe a bit more about how you would like to use it?
it is a testing device , the only position feedback is transmitted by CAN or CAN FD. Because motion is slow, i purpose to use a getway get the position feedback.
A converter will introduce some delay. For feedback, delay can be quite problematic. However, if the system responds very slowly to actuator input, then it may work well enough. If this is the case, then will probably work to convert the CAN position feedback data to EtherCAT and then assign that data as axis feedback.
