When using the Force Rate Filter to make the force display and plotting easier to read, is the register for the filtered value accessible? I want to display it on an HMI.
The filtered value is the Force Rate, which is visible in the Axis Status Registers, on the All tab, in the Pressure/Force feedback section. For details on it, click it and press F1 to open the help.
I’m wondering if I can access the register that the filtered force is in. I assumed it wouldn’t be F8:23, or is it?
The filtered force is ineed in F8:23. The Force Filter applies to the Actual Force and the Force Rate Filter applies to the Force Rate.
