To run DCSMON on Windows 7 and newer, you will need to use a DOS emulator. DOSBox is a free, open source program that works well with a variety of old DOS programs.
- Install DosBox from http://www.dosbox.com/download.php?main=1
- Create a folder C:\DOS
- Place the DCSMON directory in C:\DOS
- Modify DOSBox configuration (Start Menu->DOSBox Options)
In the [serial] section
serial1=directserial realport:COM1
in the [autoexec] section
mount C C:\DOS
- Save and close the configuration file
- Run DOSBox
- Type the following commands:
C:
cd DCSMON
DCSMON
