Encoder Requirements
To interface with an RMC motion controller, an incremental encoders must provide the following:
- 5V differential line driver output(RS-422)
- A+, A-, B+, B- signals
- Z+ and Z- signals are optional, and are used if you need to home the axis
- Higher resolution is usually always better.*
*The only exception is for extremely high rotational speeds. The RMC75E can handle 8 million counts per second (3 million lines/sec) and the RMC150 can handle 4 million (1 million/sec). High speeds may require lower resolution so this maximum is not exceeded.
Example Encoders
Many Delta customers have successfully used the following incremental encoders:
BEI
Example Part Number: H25D-F1-SS-4096-ABZC-28V/5-S-M18
http://www.beiied.com/incremental_encoders.html
Dynapar
Example Part Numbers:
HD251409604A0
H5820480003E0
Make sure to select the 5-26V in, 5V Differential Line Driver Out when configuring the encoder part number.
Encoder Products Company
Example Part Number: 15S-19-M1-4096V1RHV-K00
http://www.encoder.com/quickreference.html
Heidenhain
Heidenhain uses the term TTL for its RS-422 incremental quadrature signal. This is compatible with the RMCs.
Notice that many other manufacturers use the term TTL for single-ended signals, which are not compatible with the RMC75.
Leine Linde
1041589-01
Make sure to select RS422 as the incremental output.
http://www.leinelinde.com/products/heavy-duty-encoders/
Sick Stegmann
DFS60A-S4AK65536 (The DFS60 supports up to 65,356 pulses/rev)
DRS20-2F408192
https://www.sick.com/us/en/encoders-and-inclination-sensors/incremental-encoders/c/g244396
