Is it possible to plot Jerk?
I have an EMA application with a linear axis where a servo motor is directly driving a ball screw to lift a load. During the predominate portion of this machine’s life, it will be oscillating a load in a sinusoidal fashion.
For purposes of ensuring that I am not exceeding the limits of my ball screw, I’d like to plot the Jerk of the system. Would I accurately represent Jerk by using the Plotting>Advanced>Rate of Change formula on Acceleration?
Peter K
Yes, Jerk is accurately represented by using the Plotting>Advanced>Rate of Change formula on Acceleration. This works very well for the Target. It doesn’t work so well on the Actual, due to the extreme quantization error.
Jacob-
Thanks for the tip about using target acceleration! I hadn’t considered this and it makes a big difference on the result (attached)
Jerk Tar Vs ACT.rmcplots (2.03 MB)
That looks good! I am surprised the actual jerk shows up so cleanly, but looks like the filtering on the actual acceleration is pretty good, which helps a lot.
