I was working on a RMC200 project recently where I had generated a program using CA4 output cards. Between the time the program was created and the hardware was installed, we changed to CV8 output cards instead, and the card order changed slightly. When I changed the card types, it deleted quite a few of my defined axes and defaulted the remaining ones.
Is there some way to not make the software auto-delete the axes configuration? Later on if I want to add another card I would rather not have to re-program my entire axis setup. It would be nice if the software worked similarly to Controllogix software, where you can change the card slot and the software makes the necessary updates in the background. On cards that are removed, perhaps instead of deleting the axes, there could be an “unassigned” field for the control output and feedback inputs and prompt the user to re-assign those values?
Unfortunately, changing modules will result in the problems you encountered. We do plan on changing it in the future so that it will be ‘unassigned’ as you mentioned. Your request increases the priority of this feature.
I have an application that uses an RMC200Lite with a B7L base. My B7L has two open slots and just bought another A8 analog input module to add more reference axes for data acquisition, but after receiving the module, I read that I will have to start over from scratch with brand new programs. (1) Since I am adding reference axes (input only), can I add the A8 module on an open slot and collect data on new reference axes by adding the new module and axes to existing programs, or do I have to start over from scratch with new programs? (2) Also, can I plug in my new module and still use my existing programs, or will the module’s presence make my old programs not work correctly, even if I’m not collecting data from the new reference axes?
You can add a new module and add more axes without having to redo any of your programing. The new modules presence as well as the additional reference axes should not impact your old user programs.
