I just started using the new pressure autotune. It took me a few minutes because I was trying to select the plot when it appears to take the last plot uploaded. I also had my P gain to low to start and had to make some big jumps before I got it to start moving. Once I got a pressure ramp setup on the buttons things moved along very well. It took me maybe 10-15 minutes from start to finish to get it where I thought it was good. I don’t use pressure mode much but I do use pressure limit. When I started running my normal cycle with a pressure limit I got a lot of oscillations. So I backed my tuning down some and it smoothed out. I think this could be a common problem at least for me. Even on the position tuning I can set the gains to high and they look good while tuning but still need some fine tuning when I put it in the cycle. So I think this will just take some time to learn how far I can go with it. Over all the pressure autotune works very well.
I like the interface changes that you guys have done. Most of my work is done on a 15" monitor or on a smaller laptop so screen space is a premium. One thing that I would like to see different is the renaming of plots. It seems like sometimes I can click on the name and changes it and sometimes I can’t. I think if you could right click on the name and select “rename” that would be much easier.
