Pressure Transducers
For high-performance motion control, pressure transducers need to have fast response, on the order of 1 msec or less.
Ashcroft
Ashcroft offers many transducers.
Standard Industrial: A2 http://www.ashcroft.com/products/pressure_transducers_transmitters/high/A2-Transmitters.cfm
High-Performance: G2 (<1ms response time) http://www.ashcroft.com/products/pressure_transducers_transmitters/high/G2-Transducer.cfm
HYDAC
HDA 4000 and HDA3800 Series http://www.hydacusa.com/
Milwaukee Cylinder
SGPS Series (<1ms response time): https://www.milwaukeecylinder.com/pdfs/sgps-series-datasheet.pdf
NOSHOK
Series 100, 200, 615/161. http://www.noshok.com
NOSHOK also offers pressure transducers with various hazardous location designations.
Rexroth
HM20 pressure transducers (<1ms response time) http://www.boschrexroth.com/en/xc/
Wika
S10 pressure transducers, (<1ms response time) http://www.wika.us/
When specifying Rexroth pressure transducers, be particularly careful about something the manufacturer calls “Component Series”. Series 1X and 2X are both available for order (at the time of this post), however the 2X Series is intended to supersede the 1X. When I took the HM20’s 1X data sheet to Delta, the engineers discovered a notation about resolution, which is described as 11-bit. Nobody I’ve talked to has yet determined why or when a A/D - D/A converter was ever put into the transducer. The data sheet for Component Series 2X has no such notation, and was described by a Rexroth engineer as having no digital conversion. In short, a 1X may work, but be vigilant and suspicious.
