Mentioned in the help
“Note:This bit turns on only when exceeding the limit or attempting to go further past the limit. It will turn off if a command is issued that keeps the axis in the same place or moves it toward the limit.”
If the axis is outside the range of the negative limit,In this case, move the axis in the opposite direction,Will Negative Overtravel trigger?
Did a test, still report Negative Overtravel.I think it should not be triggered at this time because it is triggered in the opposite direction. I used instruction Open Loop Rate
Plot1.rmcplots (2.82 MB)
