its been at least 2 years and now i need to change the Ramp Rate of a Quick Move Absolute command. Not sure if increasing or decreasing the variable make the move faster or slower?
Increasing the Output Ramp Rate (V/sec) will make the voltage to the valve change faster. If the components and mechanics (physics) of the system allow it, the axis should speed up faster.
Increasing the Deceleration Rate (position units /s^2) will cause the control loop to wait longer before decelerating. Again, theoretically the move will be faster if the rest of the system is designed to allow for that rate.
You should read the help on the Quick Move Absolute. It has some other good information on what to look out for.
