We are looking at a project which will result in a multitude of plots of a single axis. I have been researching the RMC Tools training manual about viewing plots, capture mode, and trend mode. We are looking at potentially thousands of plots in a day. I have not found any information on how to set up an automatic export of plots as they are generated.
Is there a method for automatically exporting this data from our RMC75E through the ethernet or USB?
You can interface the RMC controllers with Labview or you can use .NET programs to interface with the RMC
Have a look here: deltamotion.com/products/sof … mclink.php
Someone from Delta will likely chime in soon as well.
I have only used the .NET interface for demo purposes but it seems very easy and robust.
Delta’s RMCLink .Net Assembkly and Active X Control comes with a Microsoft Excel spreadsheet example that automatically uploads each new plot from the RMC75E (from a single plot configuration) and saves it. Each plot is saved in a format that can be opened by the RMCTools Plot Manager. I think this will do exactly what you are asking for.
