RMC200 Power consumption
The attached Excel spreadsheet can be used to calculate the approximate power consumption of the RMC200. The consumption data is from the RMC200 datasheet, which lists maximum consumption, assuming all I/O points on the module are used (with differences depending on current vs. voltage or exciter output usage). This should yield a conservative estimate.
RMC200 power consumption.xlsx (11.8 KB)
