I’m using a RMC75E-AA2. It’s my understanding that scaling is handled by Pressure Scale (Pr/V) F12:0 and Pressure Offset (Pr) F12:1. This assumes that the input is linear.
Is it possible to have a lookup table for scaling non-linear input?
Although it is not possible to scale non-linear inputs, it may still be possible to make non-linear applications work by using the mathematical expressions in RMCTools.
These types of applications require two parts:
Continuously calculate the scaled pressure
With the expressions in RMCTools, you can make a user program that continuously calculates the true scaled pressure. You can put the result in a variable, and monitor that variable. You can do this for both the Target Pressure and Actual Pressure.
With these two steps, you can correctly determine the target pressure, and you can monitor the scaled target and actual pressure. That’s usually all you need for basic pressure control. If you need to do custom profiles, this method may not be enough.
