U14 with 2 load cell inputs instead of 4 analog inputs
Hi,
It would be nice to have a second version of the U14 card but with 2 load cell inputs instead of 4 analogs inputs.
The LC8 module is nice, but we rarely see projects that needs more than 1 or 2 load cell inputs.
We ofen do hydraulic press projects that require to control 1 or 2 axes that use SSI position feedbacks and load cells.
Thank you for the request. Yes, we also have been considering the load cells applications that are only 1 or 2 axes. The RMC200 is rather expensive for 1 or 2 axis applications, although it does offer faster loop times. I am curious, for most applications, do you feel it would be better with a U14 module with load cell inputs, or perhaps some other solution, for example, an expansion module on the RMC75 with one load cell input?
-Jacob Paso
Many of my customers need load cell input module instead of AP2 module for RMC75.
Thank you for the input. A 1 or 2 axis load cell input is now firmly on our roadmap but will still be at least a couple years away. For the time being, a load cell amplifier will be needed. We had started on this before the pandemic, but our development time was diverted to supply chain issues.
Good to hear that. For most of the controller in testing field, load cell input is a basic interface.
