Using RMCLink on 64-bit Windows
RMCLink version 3.1 supports 64-bit Windows applications. Previous RMCLink versions supported only 32-bit applications.
Delta recommends upgrading RMCLink to version 3.1. Both a 32-bit and a 64-bit version are available.
http://www.deltamotion.com/dloads/downloads.php?category=rmc150&subcategory=.NET/ActiveX/LabVIEW
I have a Windows Forms application that I have developed using a 64-bit machine. I assume that I need RMCLink installed on the target machine as well? The target machine is a 32-bit Windows 7 machine.
Don
Yes, RMCLink must be installed on the target machine. Your windows Forms application must of course be compiled for a 32-bit machine, and the target machine will need the 32-bit RMCLink.
