when the profinet occurred An error ,How to respond to error,halt? or else.
I cant find the configration in rmctool?
The following help topics in RMCTools list the tags available that indicate a lost PROFINET connection:
http://deltamotion.com/support/webhelp/rmctools/Communications/Ethernet/Supported_Protocols/PROFINET/PROFINET_Handling_Broken_Connections.htm?nav=index&scroll=30312
You can make a condition in the Program Triggers using one of these tags, that starts a user program that properly shuts down the machine.
Thanks for your reply。
for example:
When i use Direct Output 1.0v 100v/s, the profinet lost.If i dont deal with the error, the rmc150 always output 1.0v?
Yes.
I think the rmc150 can add the Function。
When the profinet occur error,the error bits can include this error bit, and in the auto stop configuration , can Configuration the stop mode
I also think a feature like that could be useful. In the meantime, the Program Triggers can be used to properly stop the motion and user programs.
