Where to find wiring diagrams
We often receive questions about where to find wiring diagrams, schematics or pin-outs for the RMC75, RMC150, and RMC200. Here are the various places you can find wiring informaton:
RMC200 Startup Guide, RMC150 Start-Up Guide or RMC70 Startup Guide.
This is shipped with each unit and can also be downloaded as follows:
Go to http://www.deltamotion.com/.
On the upper horizontal menu bar, click Support & Training, then select Downloads.
On the left vertical menu under RMC200, RMC150/151 or RMC70, click Manuals.
Choose RMC200 Startup Guide, RMC150 Startup Guide or RMC70 Startup Guide.
This startup guides are fairly short (approx. 40 pgs) and may be worth printing if you do not have the copy that was shipped with the unit. The wiring diagrams are toward the back in Appendix A.
RMCTools Help
This is included in the RMCTools software:
On the Help menu, click Help Topics.
On the Index tab, type “wiring” (don’t type the parentheses).
Under wiring, click the module that you need wiring info for.
RMCTools can be downloaded from Delta’s website as follows:
On the upper horizontal menu bar, click Support & Training, then click Downloads.
Click Software.
Choose RMCTools.
RMC70/RMC150/RMC200 Motion Controllers and RMCTools User Manual
Notice that the user manual contains the same wiring diagrams that are in the RMCTools help. The user manual can be downloaded as follows:
On the upper horizontal menu bar, click Support & Training, then select Downloads..
On the left vertical menu under RMC200, RMC150/151, or RMC70, click Manuals.
Choose RMC70/150/200 Motion Controllers and RMCTools User Manual. The Wiring chapter contains the wiring diagrams.
Search terms: wire, wires, wiring, schematic, pinout, pin-out, pin out, pins
