Why is there only one Acceleration Feed Forward ? Not like the Velocity Feed Forward including positive and negative?
The gains and acceleration feed forward are all ratioed based on the ratio of the velocity feed forward. If the system appears to need a different positive or negative acceleration feed forward, it usually means that there are other problems that need to be solved in a different manner.
