Anybus X-Gateway Protocol Converter
The HMS corporation’s Anybus X-Gateway device converts between many protocols by acting as a gateway between networks. To use with the RMC75E and RMC150E, choose an Anybus X-gateway model with EtherNet/IP Scanner/Master. This can convert to protocols such as EtherCAT, DeviceNet, CC-Link, CANopen, etc.
http://www.anybus.com/
Attached is a document explaining how to set up the EtherNet/IP Scanner/Master portion of the gateway so that it can communicate with the RMC75E or RMC150E. For setting up the protocol on the other side of the gateway, refer to the Anybus documentation.
Anybus X-Gateway Setup – EtherNetIP.pdf (712 KB)
