Ethernet to Serial RS-232 Converters
The RMC150E and RMC200 motion controllers do not natively support serial RS-232 or RS-485 communication but can communicate to serial RS-232 and RS-485 devices by using a third-party serial-to Ethernet converter.
The serial device must support Modbus/RTU or Allen-Bradley DF1.
Here is how to communicate with the RMC75E, RMC150E, or RMC200 via serial communications:
  1. Choose your protocol, either Modbus/RTU or DF1. These are the only ones supported at this time.
  2. Purchase a converter for your protocol:
Delta has tried these converters and found them to work well.
Using the 515RTAENI.pdf (145.9 KB)
Using the Lantronix UDS1100.pdf (277 KB)
Using the 1761-NET-ENI.pdf (256 KB)
Using the Spectrum Universal Gateway.pdf (171.5 KB)
