I have an RMC200 that I want to interface with via a Linux system. I am looking for basic controls and the ability to read/write variable names. Is there a sample program that demonstrates this functionality?
Hello Jon,
Yes, I believe the example you are looking for is this one:
The .zip file linked in the above topic has a C example. As far as reading and writing variable tags, that cannot be done via DMCP. You would need to define your variable tags with RMCTools software and flash the controller’s non-volatile memory, but once the variables have been defined then you can read and write to them directly.
For details on formatting DMCP packets, see:
Communicating Directly via TCP
Communicating Directly via UDP
